preCICE mesh id (-1) error (OpenFOAM+CalculiX CHT)
ccx_preCICE -i Solid/flap -precice-participant Calculix
Maybe just a typo here, but in your preCICE config the participant’s name is CalculiX.
Do you now get a “mesh empty” error message or “mesh ID unknown” error?
Could you please double check that in your CalculiX mesh files surface is defined correctly?
If you want you could already open a draft PR in the tutorials repository as what you do would be a (first step towards a) solution to Missing flow-over-heated-plate with CalculiX · Issue #103 · precice/tutorials · GitHub. Then, we could try to run your complete case and reproduce your problem.
Why do you want to use chtMultiRegionFoam and not bouyantPimpleFoam here?
