- preCICE version 2.3.0
- Operating system or platform (centos 7 on login-node of supercomputer cluster)
- Installation method (building with CMake)
- Dependency versions (especially compiler, Boost, PETSc, MPI) and if other versions are present.
GCCcore/6.4.0
OpenMPI/2.1.2-GCC-6.4.0-2.28
foss/2018a
libxml2/2.9.7-GCCcore-6.4.0
binutils/2.28-GCCcore-6.4.0
OpenBLAS/0.2.20-GCC-6.4.0-2.28
bzip2/1.0.6-GCCcore-6.4.0
ncurses/6.0-GCCcore-6.4.0
GCC/6.4.0-2.28
gompi/2018a
zlib/1.2.11-GCCcore-6.4.0
CMake/3.13.2-GCCcore-6.4.0
numactl/2.0.11-GCCcore-6.4.0
FFTW/3.3.7-gompi-2018a
Boost/1.70.0-foss-2018a
hwloc/1.11.8-GCCcore-6.4.0
ScaLAPACK/2.0.2-gompi-2018a-OpenBLAS-0.2.20
XZ/5.2.3-GCCcore-6.4.0
cmake -DPRECICE_ALWAYS_VALIDATE_LIBS=ON -DPRECICE_InstallTest=ON -DMPI_CXX_COMPILER=mpic++ -DBUILD_SHARED_LIBS=ON -DCMAKE_BUILD_TYPE=Release -DEigen3_DIR=/vsc-hard-mounts/leuven-data/327/vsc32782/dummy/eigen-3.4.0/ -DCMAKE_INSTALL_PREFIX=/vsc-hard-mounts/leuven-data/327/vsc32782/dummy/precice_install -DPRECICE_MPICommunication=ON -DPRECICE_PETScMapping=OFF -DPRECICE_PythonActions=OFF … &> log
cmake-log.txt (9.0 KB)
make-log.txt (258.2 KB)
Hi, I keep on running into the same error during the make-process with fmt ‘specialization of struct formatter in different namespace’. In attachment you can find the log-files of the cmake procedure and the make-procedure. I have made earlier versions of precice from source without problem, so therefore I’m puzzled with this error.
Kind regards,
Jurgen
