I’m installing preCICE in a Debian 9 container. As the os is quite old, most of the dependencies are missing or outdated. Nevertheless, by following the installation instructions I set up all dependencies and started configuring preCICE.
Some info:
- preCICE version 2.5.0
- Operating system Debian 9 in a container
- Installation method : CMake
- Dependency versions appear to be fulfilled:
- cmake 3.24.1
- eigen 3.3.7 (manually installed)
- boost 1.74.0 (manually installed)
- PETSc 3.12.4 (manually installed)
- MPI 2.0.2 (system… not usable?)
- gcc 6.3 (system) in particular
g++ -vgives gcc.log (1.4 KB)
The command
cmake .. -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX=/opt/software/precice
looks good to me (apart from MPI, maybe): cmake.log (5.1 KB)
Nevertheless make make.log (18.4 KB) throws errors like
fmtEigen.hpp:9:13: error: specialization of ‘template<class T, class Char, class Enable> struct fmt::v9::formatter’ in different namespace [-fpermissive]
Before touching compiler flags and so on, I wonder if the compiler uses the right standard and if there are other issues I’m not aware of.
Thank you
