porousMultiphaseFoam and OpenFOAM-CalculiX Coupling
Hello,everyone,
I want to simulate groundwater seepage . I want to use porousMultiphaseFoam(an open-source toolbox for OpenFOAM)
Can I use porousMultiphaseFoam for OpenFOAM-CalculiX Coupling?
Thanks.
I don’t know, but maybe @Alphaoo1 or @ajaust have encountered this solver in the context of preCICE.
Generally, any standard OpenFOAM solver can be used with the OpenFOAM-preCICE adapter, as long as it follows the typical structure of OpenFOAM solvers (most importantly: calls function objects). But, since you want to couple porous media related fields, you may need to extend the adapter for those: Extend the OpenFOAM adapter | preCICE - The Coupling Library
Hi! I have never used the OpenFOAM porous-medium solver and never got around testing it. In my project we always used DuMuX for the porous-medium solver which is a package highly specialized in solving various porous-medium problems.
Hi :slight_smile:
Sorry for the late reply.
I have used VoF (interFoam) solver for multiphase flow.
I have added a field for porosity and a field called source to createFields.H. (I have to compile this solver with additional fields using wmake).
I then use fvOptions (fvModels for OF v9) with vectorCodedSource to compute the “drag” source and inject it into the momentum equations.
Here is the example,
porousSource
    type            vectorCodedSource; // coded source for the effect of the porosity using Darcy-Forchheimer formula
    active          true;
    selectionMode   all;
    fields          (U);
    name            sourceTime;
    codeCorrect
    codeAddSup
            //volVectorField& source = mesh_.lookupObjectRef<volVectorField>("source");
            vectorField& Usource = eqn.source();
            const volVectorField& Velocity = eqn.psi() ;
            const volScalarField& porosity = mesh_.lookupObject<volScalarField>("Volume_Porosity");    // get the porosity field
            const volScalarField& MU = mesh_.lookupObject<volScalarField>("mu"); // dynamic viscocity
            const vectorField& C = mesh_.C();   // get the cell centers of the mesh
            const scalarField& V = mesh_.V();   // get the cell volume (a specific source is wanted, ie /m^3)
            const scalar Dp = 0.01 ;  // : Dp = mean diameter of the particles
            scalar alpha = 0;
            forAll(C, i) // for every cell
                    alpha = 0;
                    if (porosity[i] != 0 && porosity[i] != 1)
                            alpha = (pow(Dp, 2)/150) * (pow(porosity[i], 3)/pow((1-porosity[i]), 2));
                            Usource[i] = ((MU[i]/alpha)*Velocity[i] ) * V[i] ;
I hope this helps.
Cheers,
Prasad
