OpenFOAM-CalculiX: Fluid part stuck at "---[precice] Setting up primary communication to coupling partner/s"
perpendicular-flap-OF-Calculix.zip (24.1 KB)
I try to use OpenFOAM-Calculix. I installed the OpenFOAM-adaptor and calculix-adaptor. I run two different cases, all being faced with stuck at “—[precice] Setting up primary communication to coupling partner/s”, when using openfoam-adaptor to run.
My file is attached. I open two terminals and run separately at the same time: The soild part could run until the end, but I did not see something like:"—[precice] I am participant “Solid”
—[precice] Setting up primary communication to coupling partner/s" in the log
The fluid terminal just stuck at “—[precice] Setting up primary communication to coupling partner/s”.
I thought it may be that the openfoam v2406 is incompatible, so I installed openfoam-10, but the same problem occurs.
Are there any potential reasons for this? Thanks!
solved! we should use ccx2.20, not ccx 2.21
