I am following the tutorial to setup ASTE as I need to investigate the difference between the mapping methods available in preCICE for my master thesis. I use the meshes from the tutorial (ASTE (artificial solver testing environment) wind turbine blade tutorial | preCICE - The Coupling Library).
I ran the following command to generate the data:
precice-aste-evaluate --mesh meshes/0.01.vtk --function franke3d --data "dummyDataA"
precice-aste-evaluate --mesh meshes/0.03.vtk --function franke3d --data "dummyDataB"
The precice-config.xml looks like this:
<precice-configuration>
<log>
<sink
format=" ---[precice] %ColorizedSeverity% %Message%"
enabled="true" />
</log>
<data:vector name="Forces"/>
<data:vector name="Displacements"/>
<mesh name="Fluid_Centers" dimensions="3">
<use-data name="Forces"/>
</mesh>
<mesh name="Fluid_Nodes" dimensions="3">
<use-data name="Displacements"/>
</mesh>
<mesh name="Structure_Nodes" dimensions="3">
</mesh>
<participant name="A">
<provide-mesh name="Fluid_Nodes" />
<provide-mesh name="Fluid_Centers" />
<receive-mesh name="Structure_Nodes" from="B"/>
<read-data name="Displacements" mesh="Fluid_Nodes"/>
<write-data name="Forces" mesh="Fluid_Centers"/>
<mapping:rbf direction="write" from="Fluid_Centers" to="Structure_Nodes" constraint="conservative">
<basis-function:compact-polynomial-c6 support-radius="1.0" />
</mapping:rbf>
<mapping:rbf direction="read" from="Structure_Nodes" to="Fluid_Nodes" constraint="consistent">
</mapping:rbf>
<watch-integral mesh="Fluid_Centers" name="ForcesIntegralCC" scale-with-connectivity="no"/>
<export:vtu directory="preCICE_exports" every-n-time-windows="100" every-iteration="false"/>
</participant>
<participant name="B">
<provide-mesh name="Structure_Nodes" />
<watch-point mesh="Structure_Nodes" name="point1" coordinate="0.6; 0.2; 0." />
<read-data name="Forces" mesh="Structure_Nodes"/>
<write-data name="Displacements" mesh="Structure_Nodes"/>
</participant>
<m2n:sockets acceptor="A" connector="B" exchange-directory="./" network="ib0"/>
<participants first="A" second="B"/>
<time-window-size value="0.001" />
<max-time-windows value="1000" />
<max-time value="1"/>
<exchange data="Forces" mesh="Structure_Nodes" from="A" to="B" initialize="yes"/>
<exchange data="Displacements" mesh="Structure_Nodes" from="B" to="A" initialize="yes"/>
</precice-configuration>
I thought that running precice-aste-evaluate would create a .vtu file containing the mesh plus the dummy data. No such a file is created (a .vtk file is created in the folder where the command is ran), but it appears that no mesh is present: If I run the following command to launch participant A (after renaming the generated file by precice-aste-evaluate as 0p01.vtu):
precice-aste-run --mesh 0p01.vtu --data "dummyDataA" -p A
I get the following error:
---[ASTE:A:0] INFO : ASTE Running in mapping test mode
---[preCICE:A:0] INFO : This is preCICE version 3.1.2
---[precice] This is preCICE version 3.1.2
---[preCICE:A:0] INFO : Revision info: no-info [git failed to run]
---[precice] Revision info: no-info [git failed to run]
---[preCICE:A:0] INFO : Build type: Release (without debug log)
---[precice] Build type: Release (without debug log)
---[preCICE:A:0] INFO : Configuring preCICE with configuration "precice-config.xml"
---[precice] Configuring preCICE with configuration "precice-config.xml"
---[preCICE:A:0] INFO : I am participant "A"
---[precice] I am participant "A"
---[ASTE:A:0] ERROR : Unable to handle basename 0p01.vtu no meshes found
I am a bit confused here. Is this happening because I didn’t partition the mesh using the given tool?
Thank you in advance for your help.
