Hello, preCICE official team,
I have been trying to write my own FLUENT adapter in order to achieve the coupling of three FLUENT instances. However, I have encountered some issues during the process. For simple cases with well-matched coupling interfaces, I am able to successfully invoke the preCICE initialization API and achieve initialization. However, for more complex cases where the coupling interfaces seem to differ significantly, I am unable to initialize due to mapping issues. Therefore, I would like to inquire if you could provide some guidance or suggestions for resolving this problem. Your assistance would be greatly appreciated. Thank you so much.
Here is the configuration file I am using for the coupling。
precice-config (2).xml (3.5 KB)
This is the console output information from Coupling Participant 1.
This is the console output information from Coupling Participant 2.
This is the console output information from Coupling Participant 3.
