I am not sure I understand your question. Could you describe the problem a bit more? Is it maybe a flow above a porous medium?
If yes, then this is not trivial to do with the adapter at the moment, you may need to extend it. But I believe that @ajaust could have some nice resources to point you to regarding this.
I coupled two fluids with each other, but some slip coupling condition (Beavers-Joseph) instead of a moving wall. If it is still of interest, I can find some of the resources.
