Data exchange during sub-iteration of implicit coupling
Hello preCICE team,
I am using preCICE for volume couplings of two solvers. Implicit coupling is used to simulate unsteady motion of system of interest. I wonder if data exchange during the sub-iteration of the implicit coupling is feasible or not. For example, if the implicit coupling dt is 1e-3 s, and I want to make 20 sub-iterations between each dt marching, is it allowed by preCICE to let the codes exchange the data during the 20 sub-iterations? I was trying to dig the tutorial case of FSI, but could not figure out this yet. Any comments/notes will be extremely helpful.
Sincerely,
Hi @smjo1021,
sounds to me what you are looking for is the time interpolation feature: Waveform iteration for time interpolation of coupling data | preCICE - The Coupling Library
This does not do what you ask for, but probably does what you want to achieve.
@BenjaminRodenberg would be the expert to ask regarding this.
In short
  • data exchange happens at the end of the time window
  • there can be multiple iterations per time window
  • doing multiple substeps produces samples
  • samples can be used for time interpolation (piece-wise linear by default) in the next iteration of the same time window
Hope that helps
