I have just started using precice for fluid-structure coupling calculation related to flexible plates. I have modified the perpendicular flap case, but this is reported wrong.
Please help me to see why, how to modify? Thank you very much!
Hello @zyx,
A few things to look at:
time-window-size in precice-config.xml and OpenFOAM Fluid/system/controlDict time step deltaT
Fluid/constant/dynamicMeshDict is set up properlyMight not be the case but asking based on the output, is your deltaT = 0?
Thank u very much!
I have solved the problem. The reason is that the solver does not support dynamic grid solving.
But I have a new problem, and I’d like to ask you about it if you can. I modified the perpendicular-flap case to cancel the incoming flow and add a bubble near the elastic plate, hoping that bubble collapse would cause displacement and deformation of the plate. But the solid solution diverges at coupling. There is no displacement of the plate and only a small deformation in the result.
I wonder if you understand why the solid solution diverges?
Good that you solved the original issue! ![]()
I see that you opened multiple topics for the same question. Please keep one topic per question, and one question per topic.
I marked your last answer as the solution. Please do the same when you manage to solve the respective issue of each thread.
Let’s continue the discussion in Caculix diverged when solved elasitic plate FSI problem with openfoam
