Hello, I am trying to code up a ANSYS CFX adaptor, but having an error at initialization stage. Here is the error I have right now.
(0) 00:36:48 [impl::SolverInterfaceImpl]:251 in initialize: Setting up master communication to coupling partner/s
terminate called after throwing an instance of ‘std::bad_alloc’
what(): std::bad_alloc
WARNING: CFXSTP called recursively.
An error has occurred in cfx5solve:
I am using mpi for communication. PreCICE version is 2.1.1. CFX, precice and my coupling code are all compiled with intel compiler.
I also tried sockets for communication, but this gives the following error when executing precicef_create.
*** Error in `/usr/ansys_inc/v202/CFX/bin/linux-amd64/ifort/solver-mpi.exe’: free(): invalid pointer: 0x00007ffce9a92fb8 ***
After installing preCICE, I run the ctest. All the tests are OK, as shown in the following.
Test project apps/precice-2.1.1/build
Start 1: precice.acceleration
1/28 Test #1: precice.acceleration … Passed 0.67 sec
Start 2: precice.action
2/28 Test #2: precice.action … Passed 0.39 sec
Start 3: precice.com
3/28 Test #3: precice.com … Passed 1.30 sec
Start 4: precice.com.mpiports
4/28 Test #4: precice.com.mpiports … Passed 0.45 sec
Start 5: precice.cplscheme
5/28 Test #5: precice.cplscheme … Passed 4.71 sec
Start 6: precice.io
6/28 Test #6: precice.io … Passed 0.47 sec
Start 7: precice.m2n
7/28 Test #7: precice.m2n … Passed 0.47 sec
Start 8: precice.m2n.mpiports
8/28 Test #8: precice.m2n.mpiports … Passed 0.38 sec
Start 9: precice.mapping
9/28 Test #9: precice.mapping … Passed 0.64 sec
Start 10: precice.math
10/28 Test #10: precice.math … Passed 0.28 sec
Start 11: precice.mesh
11/28 Test #11: precice.mesh … Passed 0.34 sec
Start 12: precice.partition
12/28 Test #12: precice.partition … Passed 1.49 sec
Start 13: precice.interface
13/28 Test #13: precice.interface … Passed 0.24 sec
Start 14: precice.serial
14/28 Test #14: precice.serial … Passed 12.00 sec
Start 15: precice.parallel
15/28 Test #15: precice.parallel … Passed 4.93 sec
Start 16: precice.query
16/28 Test #16: precice.query … Passed 0.28 sec
Start 17: precice.testing
17/28 Test #17: precice.testing … Passed 0.27 sec
Start 18: precice.utils
18/28 Test #18: precice.utils … Passed 0.27 sec
Start 19: precice.xml
19/28 Test #19: precice.xml … Passed 0.59 sec
Start 20: precice.solverdummy.build.cpp
20/28 Test #20: precice.solverdummy.build.cpp … Passed 8.28 sec
Start 21: precice.solverdummy.build.c
21/28 Test #21: precice.solverdummy.build.c … Passed 2.20 sec
Start 22: precice.solverdummy.build.fortran
22/28 Test #22: precice.solverdummy.build.fortran … Passed 0.83 sec
Start 23: precice.solverdummy.run.cpp-cpp
23/28 Test #23: precice.solverdummy.run.cpp-cpp … Passed 0.53 sec
Start 24: precice.solverdummy.run.c-c
24/28 Test #24: precice.solverdummy.run.c-c … Passed 0.48 sec
Start 25: precice.solverdummy.run.fortran-fortran
25/28 Test #25: precice.solverdummy.run.fortran-fortran … Passed 1.12 sec
Start 26: precice.solverdummy.run.cpp-c
26/28 Test #26: precice.solverdummy.run.cpp-c … Passed 0.47 sec
Start 27: precice.solverdummy.run.cpp-fortran
27/28 Test #27: precice.solverdummy.run.cpp-fortran … Passed 0.49 sec
Start 28: precice.solverdummy.run.c-fortran
28/28 Test #28: precice.solverdummy.run.c-fortran … Passed 0.50 sec
100% tests passed, 0 tests failed out of 28
If you want to know more information, please let me know. Thanks in advance.
