HI @djmeee , the earlier tagged post provides a solution in this part which basically is to remove the stagnant unused node manually from the CalculiX mesh file. This is probably not the ideal solution and it is good that you found another solution of downgrading form CalculiX 2.16 to 2.15. Does your case also work for v2.16 normal version? Perhaps then only the Multi-thread version is the problem.
Related topics
| Topic | Replies | Views | Activity | |
| Calculix-OpenFOAM coupling strange behaviour | 1 | 285 | June 19, 2023 | |
| Sticking nodes on FSI interface in OpenFOAM/CalculiX coupling | 9 | 1563 | March 25, 2021 | |
| A case of FSI with OpenFOAM and CalculiX is stuck without any error in logs | 3 | 665 | April 15, 2022 | |
| Temperature anomaly/ Calculix OpenFoam CHT Coupling | 7 | 667 | February 16, 2022 | |
| OpenFOAM-CalculiX FSI Diverging Sim Never Ends | 21 | 2976 | September 10, 2021 |
