hi:
when i finish install aste,but failed when I run “make test”,error as follow:
my question is : why the error happened, Does it have any effect on the later tests?
Just a guess: You didn’t install the python dependencies.
To find out in detail, you can run ctest -VV --rerun-failed. To install the requirements you can run pip install -r requirements.txt. The mapping-tester is not a mandatory component of aste and we decided to not put jinja2 into the requirements.txt. You might need to install it manually as well, if you want to use the mapping-tester.
very thanks, you are welcome
