About rbf method!
@ilovenili please provide in this and in future post:
  1. A short and descriptive title: What is this post about?
  2. Fundamental information about the setup:
  • OS and distribution
  • dependencies and their versions
  • preCICE version and version of adapters if possible
  • installation procedure of the above including build configuration and flags
  • used compilers and their versions
  1. A description of the setups including:
  • which solvers are used
  • how are these solvers run
  • preCICE configuration file
  • adapter configuration files if applicable
  • log files
  1. A description of the problem:
  • which error do you encounter
  • do you have a possible explanation why the error could occur
  • what have you tried so far to fix the error
Thank you
