Turek-Hron FSI with OpenFOAM and CalculiX
Your repository can’t be accessed. Did you make it private ?
You should do a fork of precice/tutorials (which creates a copy on your Github account), make changes on the fork, then open a PR
Yes that is true, my bad.
I’ve opened another PR. I hope it works now.
Hi Johannes,
I couldnt download your 3D case fsi simulation with Precice and calculix coupling. Can you share it with me? I need the case for research on Turek benchmark as well for my thesis on Turbulent flows.
Did you get any turbulent result on that( LES modeling or other methods in higher Reynolds)?
And do you think dealii has the potential to run 3D simulation as Calculix?
Thanks. I truly appreciate your assistance in this matter.
Imanmirafzal77@gmail.con
