SU2: restarting a simulation from a deformed mesh
Hi, this is rather a question about SU2.
I have my custom 2D structural solver which properly works with SU2 through preCICE. I also coded the restart functionality in my structural solver. The problem is, when I restart a simulation, although SU2 reads the field data from a restart file, I observed that it still uses the initial mesh file (MESH_FILENAME) rather than the deformed mesh. (because I guess the restart*.dat files of SU2 does not contain the vertex coordinates?)This leads to a large inconsistency between the solvers. Is there a workaround for this in SU2?
I am using the SU2_CFD solver.
Any ideas are appreciated. Thanks!
