Hi everyone, I meet some problems when I try to couple Calculix and waves2Foam in PreCICE.
what should I do to deal it ?
thanks!
tips in ubuntu:
thanks!
tips in ubuntu:
Hi @wut_wang,
this celerityShapeFunctions does not originate from the adapter’s code, but probably from waveFoam.
What boundary conditions are you using in OpenFOAM? I can imagine that this is some case where you need to adapt the code a bit.
What are you simulating? Some wave-structure interaction scenario?
Thank you very much for your answer. I am simulating the interaction between waves and structures.
In the case of non coupling, using waveFoam can work normally, but this error will occur when coupling with Calculix through the preCICE interface。
