I want to perform 2D FSI simulation with Calculix, I saw the test case of the perpendicular flap where the mesh provided has a thickness of 1.
What happen if we put a thickness of 0.1 for the solid and we also put a thickness of 0.1 for the fluid domain ?
I wanted to know if there is an explanation for this choice of thickness and if this is also working if I want to perform the HRON&TUREK FSI3 for example?
I also noticed that you use solid element (C3D8I) for your test case, have you tried with shell elements (S4) with thickness=1 ? Because for me, contrary to shell element, having a solid element would introduce Inertia along the “fake third dimension” (If my flow is in the plan XY, the flap could have different position along the z axis).
Thank you for your help.
