My system:
OpenFOAMv2312
Ubuntu 22.04
preCICE 3.1.1
adapter 1.3.0
I am currently coupling OpenFOAM with a custom MATLAB solver using an custom version of the OpenFOAM adapter and am running into issues with OpenFOAM parallelization. I am using the interface to transfer non-geometric data, using consistent mapping. On the MATLAB side there is a single dummy mesh vertex (0 0 0). I am now running into crashes (see below) when I have a decomposed domain where one processor does not contain the patch used as an interface. If I split the domain equally, making sure that each section contains a piece of every boundary patch it all works.
Are there any good ways of handling this situation? Or do I manually have to make sure of the interface splitting?
Thanks and regards
David
---[preciceAdapter] Loaded the OpenFOAM-preCICE adapter - v1.3.0.
-[precice] e[0m This is preCICE version 3.1.1
-[precice] e[0m Revision info: no-info [git failed to run]
-[precice] e[0m Build type: Release (without debug log)
-[precice] e[0m Configuring preCICE with configuration "../precice-config.xml"
-[precice] e[0m I am participant "Fluid"
-[precice] e[0m Connecting Primary rank to 1 Secondary ranks
-[precice] e[0m Setting up primary communication to coupling partner/s
-[precice] e[0m Primary ranks are connected
-[precice] e[0m Setting up preliminary secondary communication to coupling partner/s
-[precice] e[0m Prepare partition for mesh Fluid-Mesh
-[precice] e[0m Gather mesh Fluid-Mesh
-[precice] e[0m Send global mesh Fluid-Mesh
-[precice] e[0m Receive global mesh aocs-Mesh
-[precice] e[0m Broadcast mesh aocs-Mesh
-[precice] e[0m Mapping distance min:0.01675 max:0.31825 avg: 0.18109 var: 0.00452119 cnt: 400
-[precice] e[0m Filter mesh aocs-Mesh by mappings
-[precice] e[0m Feedback distribution for mesh aocs-Mesh
-[precice] e[0m Setting up secondary communication to coupling partner/s
-[precice] e[0m Secondary ranks are connected
-[precice] e[0m Computing "nearest-neighbor" mapping from mesh "aocs-Mesh" to mesh "Fluid-Mesh" in "read" direction.
-[precice] e[0m Mapping "AngularAcceleration" for t=0 from "aocs-Mesh" to "Fluid-Mesh" (skipped zero sample)
-[precice] e[0m Mapping "AngularVelocity" for t=0 from "aocs-Mesh" to "Fluid-Mesh" (skipped zero sample)
-[precice] e[0m Mapping "LinearAcceleration" for t=0 from "aocs-Mesh" to "Fluid-Mesh" (skipped zero sample)
[1] [stack trace]
[1] =============
[1] #1 Foam::sigSegv::sigHandler(int)-[precice] e[0m iteration: 1, time-window: 1, time: 0 of 0.005, time-window-size: 0.001, max-time-step-size: 0.001, ongoing: yes, time-window-complete: no,
---[preciceAdapter] preCICE was configured and initialized
---[preciceAdapter] End of read reached
---[preciceAdapter] Setting the solver's endTime to infinity to prevent early exits. Only preCICE will control the simulation's endTime. Any functionObject's end() method will be triggered by the adapter. You may disable this behavior in the adapter's configuration.
in /sources/OpenFOAM-v2312/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
[1] #2 ? in /lib/x86_64-linux-gnu/libc.so.6
[1] #3 preciceAdapter::FSI::LinearAcceleration::read(double*, unsigned int) in ~/OpenFOAM/user-v2312/platforms/linux64GccDPInt32Opt/lib/libpreciceAdapterFunctionObject.so
[1] #4 preciceAdapter::Interface::readCouplingData(double) in ~/OpenFOAM/user-v2312/platforms/linux64GccDPInt32Opt/lib/libpreciceAdapterFunctionObject.so
[1] #5 preciceAdapter::Adapter::readCouplingData(double) in ~/OpenFOAM/user-v2312/platforms/linux64GccDPInt32Opt/lib/libpreciceAdapterFunctionObject.so
[1] #6 preciceAdapter::Adapter::adjustSolverTimeStepAndReadData() in ~/OpenFOAM/user-v2312/platforms/linux64GccDPInt32Opt/lib/libpreciceAdapterFunctionObject.so
[1] #7 preciceAdapter::Adapter::configure() in ~/OpenFOAM/user-v2312/platforms/linux64GccDPInt32Opt/lib/libpreciceAdapterFunctionObject.so
[1] #8 Foam::functionObjects::preciceAdapterFunctionObject::read(Foam::dictionary const&) in ~/OpenFOAM/user-v2312/platforms/linux64GccDPInt32Opt/lib/libpreciceAdapterFunctionObject.so
[1] #9 Foam::functionObjects::preciceAdapterFunctionObject::preciceAdapterFunctionObject(Foam::word const&, Foam::Time const&, Foam::dictionary const&) in ~/OpenFOAM/user-v2312/platforms/linux64GccDPInt32Opt/lib/libpreciceAdapterFunctionObject.so
[1] #10 Foam::functionObject::adddictionaryConstructorToTable<Foam::functionObjects::preciceAdapterFunctionObject>::New(Foam::word const&, Foam::Time const&, Foam::dictionary const&) in ~/OpenFOAM/user-v2312/platforms/linux64GccDPInt32Opt/lib/libpreciceAdapterFunctionObject.so
[1] #11 Foam::functionObject::New(Foam::word const&, Foam::Time const&, Foam::dictionary const&) in /sources/OpenFOAM-v2312/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
[1] #12 Foam::functionObjectList::read() in /sources/OpenFOAM-v2312/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
[1] #13 Foam::Time::run() const in /sources/OpenFOAM-v2312/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
[1] #14 ? in /sources/OpenFOAM-v2312/platforms/linux64GccDPInt32Opt/bin/interFoam
[1] #15 ? in /lib/x86_64-linux-gnu/libc.so.6
[1] #16 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
[1] #17 ? in /sources/OpenFOAM-v2312/platforms/linux64GccDPInt32Opt/bin/interFoam
[1] =============
[18c669fa19c0:00616] *** Process received signal ***
[18c669fa19c0:00616] Signal: Segmentation fault (11)
[18c669fa19c0:00616] Signal code: (-6)
[18c669fa19c0:00616] Failing at address: 0x28cf031300000268
[18c669fa19c0:00616] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7f64a5dcd520]
[18c669fa19c0:00616] [ 1] /lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c)[0x7f64a5e219fc]
[18c669fa19c0:00616] [ 2] /lib/x86_64-linux-gnu/libc.so.6(raise+0x16)[0x7f64a5dcd476]
[18c669fa19c0:00616] [ 3] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7f64a5dcd520]
[18c669fa19c0:00616] [ 4] /home/user/OpenFOAM/user-v2312/platforms/linux64GccDPInt32Opt/lib/libpreciceAdapterFunctionObject.so(_ZN14preciceAdapter3FSI18LinearAcceleration4readEPdj+0x41c)[0x7f649958bb7c]
[18c669fa19c0:00616] [ 5] /home/user/OpenFOAM/user-v2312/platforms/linux64GccDPInt32Opt/lib/libpreciceAdapterFunctionObject.so(_ZN14preciceAdapter9Interface16readCouplingDataEd+0xf2)[0x7f6499565f82]
[18c669fa19c0:00616] [ 6] /home/user/OpenFOAM/user-v2312/platforms/linux64GccDPInt32Opt/lib/libpreciceAdapterFunctionObject.so(_ZN14preciceAdapter7Adapter16readCouplingDataEd+0x36)[0x7f64995f1276]
[18c669fa19c0:00616] [ 7] /home/user/OpenFOAM/user-v2312/platforms/linux64GccDPInt32Opt/lib/libpreciceAdapterFunctionObject.so(_ZN14preciceAdapter7Adapter31adjustSolverTimeStepAndReadDataEv+0x1a6)[0x7f64995f17e6]
[18c669fa19c0:00616] [ 8] /home/user/OpenFOAM/user-v2312/platforms/linux64GccDPInt32Opt/lib/libpreciceAdapterFunctionObject.so(_ZN14preciceAdapter7Adapter9configureEv+0x1bef)[0x7f64995fdd7f]
[18c669fa19c0:00616] [ 9] /home/user/OpenFOAM/user-v2312/platforms/linux64GccDPInt32Opt/lib/libpreciceAdapterFunctionObject.so(_ZN4Foam15functionObjects28preciceAdapterFunctionObject4readERKNS_10dictionaryE+0x11)[0x7f64996352d1]
[18c669fa19c0:00616] [10] /home/user/OpenFOAM/user-v2312/platforms/linux64GccDPInt32Opt/lib/libpreciceAdapterFunctionObject.so(_ZN4Foam15functionObjects28preciceAdapterFunctionObjectC2ERKNS_4wordERKNS_4TimeERKNS_10dictionaryE+0x4d)[0x7f649963542d]
[18c669fa19c0:00616] [11] /home/user/OpenFOAM/user-v2312/platforms/linux64GccDPInt32Opt/lib/libpreciceAdapterFunctionObject.so(_ZN4Foam14functionObject31adddictionaryConstructorToTableINS_15functionObjects28preciceAdapterFunctionObjectEE3NewERKNS_4wordERKNS_4TimeERKNS_10dictionaryE+0x37)[0x7f6499635947]
[18c669fa19c0:00616] [12] /sources/OpenFOAM-v2312/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam14functionObject3NewERKNS_4wordERKNS_4TimeERKNS_10dictionaryE+0x312)[0x7f64a6a01b62]
[18c669fa19c0:00616] [13] /sources/OpenFOAM-v2312/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam18functionObjectList4readEv+0xa28)[0x7f64a6a0a2c8]
[18c669fa19c0:00616] [14] /sources/OpenFOAM-v2312/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam4Time3runEv+0x2c7)[0x7f64a6a322b7]
[18c669fa19c0:00616] [15] interFoam(+0x4d0b0)[0x56126e83e0b0]
[18c669fa19c0:00616] [16] /lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7f64a5db4d90]
[18c669fa19c0:00616] [17] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7f64a5db4e40]
[18c669fa19c0:00616] [18] interFoam(+0x59225)[0x56126e84a225]
[18c669fa19c0:00616] *** End of error message ***
Primary job terminated normally, but 1 process returned
mpirun noticed that process rank 1 with PID 0 on node 18c669fa19c0 exited on signal 11 (Segmentation fault).
