I started with a 6-way coupling with OpenFOAM+CalculiX+XDEM.
I have reduced from 6-way coupling to 4-way and now to 2-way since there seems to be an issue only in between OpenFOAM and CalculiX.
I am using modified OpenFOAM solver PorouspimpleFoam, which takes into account for porosity in addition to normal things in pimpleFoam solver. (attached in the files).
This I need because this will be used for coupling with the 3rd solver (XDEM).
I have used this Fluid with Deal.II (2-way), and it works. This also works fine with 6-way and 4-way coupling. So it seems that issue is not with Fluid.
I have taken the tutorial flap case and replaced it with the Fluid folder I have.
With all the settings kept the same as the tutorial case, I get a PETSc error
smoothSolver: Solving for cellDisplacementy, Initial residual = 0, Final residual = 0, No Iterations 2
[0]PETSC ERROR: Caught signal number 8 FPE: Floating Point Exception,probably divide by zero
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
[0]PETSC ERROR: to get more information on the crash.
[0]PETSC ERROR: User provided function() line 0 in unknown file
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 59.
So read about the issues with rbf mapping (Parallel calculation problem for OpenFOAM-CalculiX Perpendicular flap tutorial) and replaced it with nearest-neighbour mapping.
<mapping:nearest-neighbor direction="write" from="Fluid-Mesh-Faces" to="Solid" constraint="conservative" />
<mapping:nearest-projection direction="read" from="Solid" to="Fluid-Mesh-Nodes" constraint="consistent" />
I get the following error:
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 void Foam::fvc::surfaceIntegrate<double>(Foam::Field<double>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/prasad/OpenFOAM/prasad-7/platforms/linux64GccDPInt32Opt/bin/PorouspimpleFoam"
#4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::surfaceIntegrate<double>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/prasad/OpenFOAM/prasad-7/platforms/linux64GccDPInt32Opt/bin/PorouspimpleFoam"
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<double>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/prasad/OpenFOAM/prasad-7/platforms/linux64GccDPInt32Opt/bin/PorouspimpleFoam"
#6 ? in "/home/prasad/OpenFOAM/prasad-7/platforms/linux64GccDPInt32Opt/bin/PorouspimpleFoam"
#7 ? in "/home/prasad/OpenFOAM/prasad-7/platforms/linux64GccDPInt32Opt/bin/PorouspimpleFoam"
#8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#9 ? in "/home/prasad/OpenFOAM/prasad-7/platforms/linux64GccDPInt32Opt/bin/PorouspimpleFoam"
./runFluid: line 40: 18109 Floating point exception(core dumped) $solver -case Fluid
When I use <coupling-scheme:serial-explicit> the Fluid crashes at t=0.0202, no matter what the mapping. (Just error changes between PETSc and one above).
When I use <coupling-scheme:parallel-explicit> the Fluid crashes at t=0.0302, no matter what the mapping. (Just error changes between PETSc and one above).
When I use <coupling-scheme:serial-implicit> the Fluid crashes at t=0.0102, no matter what the mapping. (Just error changes between PETSc and one above).This coupling-scheme was already present (commented out) in the precice-config.xml which is available with the tutorial case.
I need help in solving this issue.
What can I try next? Different Mapping or maybe different coupling schemes.
Or is it to do with something else.
I have attached my case with the solver inside (link).
Thank you very much in advance for all the help.
Here is the link for drive:
