HI:
As above, my fluid-solid coupling is all mapped interpolation on the fluent side, what I want to ask is whether it is possible to realize the interpolation of fluent and abaqus each, and how to modify the xml file?
These are too many questions in one (edited the title to refer to the last point).
precice-config.xml. You also need that the codes themselves support preCICE (i.e., they have adapters for preCICE).If you are asking how to move one of the mappings to the abaqus participant:
read to write and swap the from/toexchange as well.In any case, visualizing the config helps: Config visualization | preCICE - The Coupling Library
All connected arrows should be pointing to the same direction.
I understood that, see my answer above:
abaqusparticipant:
