I am trying to couple two interFoam simulations with eachother, herefor I use the example damBreak from openFOAM. This simulation is extended by adding a new mesh to the right of the existing mesh. The left has as boundary conditions a fixed value for the pressure and fixed gradient for the velocity. The right side has a fixed value for the velocity and fixed gradient for the pressure. As for now I did not yet look into exchanging data of alpha. When I try to run the simulation, the following error occurs:
--> FOAM FATAL ERROR:
Attempt to cast type calculated to type fixedValue
From function To& Foam::refCast(From&) [with To = Foam::fixedValueFvPatchField<double>; From = Foam::fvPatchField<double>]
in file /opt/openfoam7/src/OpenFOAM/lnInclude/typeInfo.H at line 114.
FOAM aborting
#1 Foam::error::abort() at ??:?
#2 preciceAdapter::FF::PressureGradient::write(double*, bool, unsigned int) at ??:?
#3 preciceAdapter::Interface::writeCouplingData() at ??:?
#4 preciceAdapter::Adapter::writeCouplingData() at ??:?
#5 preciceAdapter::Adapter::execute() at ??:?
#6 Foam::functionObjects::preciceAdapterFunctionObject::execute() at ??:?
#7 Foam::functionObjectList::execute() at ??:?
#8 Foam::Time::run() const at ??:?
#9 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/interFoam"
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/interFoam"
Something goes wrong when getting data from the PressureGradient.
Does anyone knows how to solve this? The case can be found at https://github.com/chrisosse/openfoam-adapter/tree/add-breaking-dam/tutorials/FF/dambreak.
Thanks for helping in advance!
