GSoC 2026: Sudhanshu Pandey - Error messages with configuration context (C++)
Hi preCICE team,
​I am Sudhanshu Pandey, a final-year Computer Science student, and I am highly interested in taking on the Error messages with configuration context project for GSoC 2026.
​To directly answer the introductory questions:
  • ​What motivates you to spend this summer in GSoC? I want to spend my time writing production-grade C++ for a high-impact infrastructure project. I want to transition my raw algorithmic problem-solving speed into a large-scale, complex system architecture.
  • ​What interests you most about our project? The heavy reliance on core C++ and low-level memory management. Decoupling parsing from instantiation and handling configuration ASTs aligns perfectly with my background in system-level C++ and complex data structures.
  • ​Will you have any other commitments? Given that this is scoped as a Small (90h) project, I have more than enough bandwidth to fully commit to the timeline and deliverables alongside my final-year schedule.
  • ​What previous experience do you have with the respective technologies? I write C++ daily. I regularly compete in high-level algorithmic programming (currently holding LeetCode Guardian and Codeforces Expert ratings), which requires optimal time/space complexity and deep knowledge of C++ execution mechanics.
  • ​What previous experience with Git and GitHub do you have? Extensive. I use Git for all my version control, having architected, built, and deployed complex full-stack web applications and 3D virtual environments entirely from scratch using GitHub.
​Entry Test Status:
To prove my execution speed, I am currently setting up the local build to run the elastic tube 1D tutorial. My immediate goal is to break the configuration by removing the tag, trace the generic error back to the C++ source code, and modify it to provide the exact line context.
​I will be drafting my formal proposal this weekend. Are there specific XML parsing files or error-handling modules within the core library you recommend I map out first?
​Looking forward to contributing.
Github- swayamwish · GitHub
