I am trying to compile the Openfoam adapter for Precice 3.1.2 . I am using Openfoam v2406 and Intel compiler v2023.2.1. Eveything goes well until it tries to compile the object ModuleFF.o, at that point the building fails with errors that I am not able to understand. I attach the log, is someone able to help me?
Thank you @abzrg, editing those lines of the source code in the way you described worked and I was able to complete the installation of the adapter.
In any case, I am puzzled by the fact that we had to apply some changes in the source code of an official release that we just downloaded. Should we bring this to the attention of the developers for a patch?
I think It’s either a mismatch between the OpenFOAM and adaptor versions or simply a bug. If the former is not the case one can file an issue on the adaptor’s github page.
I just found this topic. Thank you for reporting issues with the Intel compiler, we indeed don’t include that in our testing. We test everything with GCC, and it is the first time for me that I see this error.
I fixed the ambiguous conversion issue in the way described here (with .cref()) in a pull request, please comment there:
Regarding the warnings for the missing override, I fixed them in another PR (already merged):
GCC does not report these by default, and we were inconsistent.
Both fixes will be included in the next bugfix release. Thanks a lot once again for reporting! Whenever you find such clear bugs, feel free to open an issue or directly contribute to the repository.
