I use an  OPENFOAM V2206 and  FENICS V 2019.1.0 in my research . ihave this error .
in fluid:
Error:
PIMPLE: iteration 5
[0] #0  Foam::error::printStack(Foam::Ostream&)[2] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
[0] #1  Foam::sigFpe::sigHandler(int) at ??:?
[2] #1  Foam::sigFpe::sigHandler(int) at ??:?
[0] #2  ? at ??:?
[2] #2  ? in /lib/x86_64-linux-gnu/libpthread.so.0
[0] #3  Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int)[2] #3  Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:?
 at ??:?
[0] #4  Foam::symGaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const[2] #4  Foam::symGaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
 at ??:?
[0] #5  Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const[2] #5  Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
[0] #6  Foam::fvMatrix<Foam::Vector<double> >::solveSegregated(Foam::dictionary const&) at ??:?
[2] #6  Foam::fvMatrix<Foam::Vector<double> >::solveSegregated(Foam::dictionary const&) at ??:?
[0] #7  Foam::fvMatrix<Foam::Vector<double> >::solveSegregatedOrCoupled(Foam::dictionary const&) at ??:?
[2] #7  Foam::fvMatrix<Foam::Vector<double> >::solveSegregatedOrCoupled(Foam::dictionary const&) at ??:?
[0] #8  Foam::fvMesh::solve(Foam::fvMatrix<Foam::Vector<double> >&, Foam::dictionary const&) const at ??:?
[2] #8  Foam::fvMesh::solve(Foam::fvMatrix<Foam::Vector<double> >&, Foam::dictionary const&) const at ??:?
[0] #9   at ??:?
[2] #9  ?? in /opt/openfoam/v2206/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/bin/pimpleFoam
[0] #10   in /opt/openfoam/v2206/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/bin/pimpleFoam
[2] #10  ?? in /opt/openfoam/v2206/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/bin/pimpleFoam
[0] #11  __libc_start_main in /opt/openfoam/v2206/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/bin/pimpleFoam
[2] #11  __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
[0] #12  ? in /lib/x86_64-linux-gnu/libc.so.6
[2] #12  ? in /opt/openfoam/v2206/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/bin/pimpleFoam
[kturbulentchbg-2:508707] *** Process received signal ***
[kturbulentchbg-2:508707] Signal: Floating point exception (8)
[kturbulentchbg-2:508707] Signal code:  (-6)
[kturbulentchbg-2:508707] Failing at address: 0x3eb0007c323
[kturbulentchbg-2:508707] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x13140)[0x7f8172789140]
[kturbulentchbg-2:508707] [ 1] /lib/x86_64-linux-gnu/libpthread.so.0(raise+0x141)[0x7f8172788fe1]
[kturbulentchbg-2:508707] [ 2] /lib/x86_64-linux-gnu/libpthread.so.0(+0x13140)[0x7f8172789140]
[kturbulentchbg-2:508707] [ 3] /opt/openfoam/v2206/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam22symGaussSeidelSmoother6smoothERKNS_4wordERNS_5FieldIdEERKNS_9lduMatrixERKS5_RKNS_10FieldFieldIS4_dEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEEhi+0x22d)[0x7f81731f8f3d]
[kturbulentchbg-2:508707] [ 4] /opt/openfoam/v2206/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam22symGaussSeidelSmoother6smoothERNS_5FieldIdEERKS2_hi+0x3b)[0x7f81731f923b]
[kturbulentchbg-2:508707] [ 5] /opt/openfoam/v2206/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam12smoothSolver5solveERNS_5FieldIdEERKS2_h+0x62a)[0x7f81731ed88a]
[kturbulentchbg-2:508707] [ 6]  in /opt/openfoam/v2206/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/bin/pimpleFoam
[kturbulentchbg-2:508709] *** Process received signal ***
[kturbulentchbg-2:508709] Signal: Floating point exception (8)
[kturbulentchbg-2:508709] Signal code:  (-6)
[kturbulentchbg-2:508709] Failing at address: 0x3eb0007c325
[kturbulentchbg-2:508709] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x13140)[0x7fe0a3da7140]
[kturbulentchbg-2:508709] [ 1] /lib/x86_64-linux-gnu/libpthread.so.0(raise+0x141)[0x7fe0a3da6fe1]
[kturbulentchbg-2:508709] [ 2] /lib/x86_64-linux-gnu/libpthread.so.0(+0x13140)[0x7fe0a3da7140]
[kturbulentchbg-2:508709] [ 3] /opt/openfoam/v2206/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixINS_6VectorIdEEE15solveSegregatedERKNS_10dictionaryE+0x789)[0x7f817643d3a9]
[kturbulentchbg-2:508707] [ 7] /opt/openfoam/v2206/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam22symGaussSeidelSmoother6smoothERKNS_4wordERNS_5FieldIdEERKNS_9lduMatrixERKS5_RKNS_10FieldFieldIS4_dEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEEhi+0x22d)[0x7fe0a4816f3d]
[kturbulentchbg-2:508709] [ 4] /opt/openfoam/v2206/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixINS_6VectorIdEEE24solveSegregatedOrCoupledERKNS_10dictionaryE+0x4f9)[0x7f8176450479]
[kturbulentchbg-2:508707] [ 8] /opt/openfoam/v2206/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam22symGaussSeidelSmoother6smoothERNS_5FieldIdEERKS2_hi+0x3b)[0x7fe0a481723b]
[kturbulentchbg-2:508709] [ 5] /opt/openfoam/v2206/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZNK4Foam6fvMesh5solveERNS_8fvMatrixINS_6VectorIdEEEERKNS_10dictionaryE+0x10)[0x7f81763f4710]
[kturbulentchbg-2:508707] [ 9] pimpleFoam(+0x3f24e)[0x55be0d55724e]
[kturbulentchbg-2:508707] [10] pimpleFoam(+0x2ce8a)[0x55be0d544e8a]
[kturbulentchbg-2:508707] [11] /opt/openfoam/v2206/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam12smoothSolver5solveERNS_5FieldIdEERKS2_h+0x62a)[0x7fe0a480b88a]
[kturbulentchbg-2:508709] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xea)[0x7f81725c5d0a]
[kturbulentchbg-2:508707] [12] pimpleFoam(+0x2f0aa)[0x55be0d5470aa]
[kturbulentchbg-2:508707] *** End of error message ***
/opt/openfoam/v2206/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixINS_6VectorIdEEE15solveSegregatedERKNS_10dictionaryE+0x789)[0x7fe0a7a5b3a9]
[kturbulentchbg-2:508709] [ 7] /opt/openfoam/v2206/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixINS_6VectorIdEEE24solveSegregatedOrCoupledERKNS_10dictionaryE+0x4f9)[0x7fe0a7a6e479]
[kturbulentchbg-2:508709] [ 8] /opt/openfoam/v2206/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZNK4Foam6fvMesh5solveERNS_8fvMatrixINS_6VectorIdEEEERKNS_10dictionaryE+0x10)[0x7fe0a7a12710]
[kturbulentchbg-2:508709] [ 9] pimpleFoam(+0x3f24e)[0x563e6bcc524e]
[kturbulentchbg-2:508709] [10] pimpleFoam(+0x2ce8a)[0x563e6bcb2e8a]
[kturbulentchbg-2:508709] [11] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xea)[0x7fe0a3be3d0a]
[kturbulentchbg-2:508709] [12] pimpleFoam(+0x2f0aa)[0x563e6bcb50aa]
[kturbulentchbg-2:508709] *** End of error message ***
Primary job  terminated normally, but 1 process returned
[1] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
[1] #1  Foam::sigSegv::sigHandler(int) at ??:?
[1] #2  ? in /lib/x86_64-linux-gnu/libpthread.so.0
[1] #3  ? in /opt/openfoam/v2206/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/lib/libforces.so
[3] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
[3] #1  Foam::sigSegv::sigHandler(int) at ??:?
[3] #2  ? in /lib/x86_64-linux-gnu/libpthread.so.0
[3] #3  ? in /opt/openfoam/v2206/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/lib/libforces.so
mpirun noticed that process rank 2 with PID 0 on node kturbulentchbg-2 exited on signal 8 (Floating point exception).
aiche231@kturbulentchbg-2:~/fluid$ mpirun noticed that process rank 2 with PID 0 on node kturbulentchbg-2 exited on signal 8 (Floating point exception).
 Sending data to another participant (using sockets) failed with a system error: write: Broken pipe. This often means that the other participant exited with an error (look there). Sending data to another participant (using sockets) failed with a system error: write: Broken pipe. This often means that the other participant exited with an error (look there).--------------------------------------------------------------------------
 at ??:?
[2] #7  Foam::fvMatrix<Foam::Vector<double> >::solveSegregatedOrCoupled(Foam::diant exited with an error (look there).-^Chis often means that the other particip
 in solid :slight_smile:
Error:---[precice]  relative convergence measure: relative two-norm diff of data "Force" = 8.31e-01, limit = 1.00e-04, normalization = 4.94e+02, conv = false
---[precice]  Time window completed
---[precice]  iteration: 1 of 3, time-window: 2, time: 5e-05 of 1, time-window-size: 5e-05, max-timestep-length: 5e-05, ongoing: yes, time-window-complete: yes, write-iteration-checkpoint
---[precice]  relative convergence measure: relative two-norm diff of data "DisplacementDelta" = 1.06e+00, limit = 1.00e-04, normalization = 1.01e-02, conv = false
---[precice]  relative convergence measure: relative two-norm diff of data "Force" = 1.06e+00, limit = 1.00e-04, normalization = 8.40e+03, conv = false
---[precice]  iteration: 2 of 3, time-window: 2, time: 5e-05 of 1, time-window-size: 5e-05, max-timestep-length: 5e-05, ongoing: yes, time-window-complete: no, read-iteration-checkpoint
---[precice]  relative convergence measure: relative two-norm diff of data "DisplacementDelta" = 9.01e-01, limit = 1.00e-04, normalization = 1.01e-02, conv = false
---[precice]  relative convergence measure: relative two-norm diff of data "Force" = 0.00e+00, limit = 1.00e-04, normalization = 8.40e+03, conv = true
---[precice]  iteration: 3 of 3, time-window: 2, time: 5e-05 of 1, time-window-size: 5e-05, max-timestep-length: 5e-05, ongoing: yes, time-window-complete: no, read-iteration-checkpoint
---[precice]  relative convergence measure: relative two-norm diff of data "DisplacementDelta" = 7.68e-01, limit = 1.00e-04, normalization = 1.01e-02, conv = false
---[precice] ERROR:  Sending data to another participant (using sockets) failed with a system error: write: Broken pipe. This often means that the other participant exited with an error (look there).
 [lrhae-HP-290:04588] Signal code: (-6) [lrhae-HP-290:04588] Failing at address: 0x3e8000011ec [lrhae-HP-290:04588] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7f41fe833520] [lrhae-HP-290:04588] [ 1] /lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c)[0x7f41fe8879fc] [lrhae-HP-290:04588] [ 2] /lib/x86_64-linux-gnu/libc.so.6(raise+0x16)[0x7f41fe833476] [lrhae-HP-290:04588] [ 3] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7f41fe833520] [lrhae-HP-290:04588] [ 4] /usr/lib/openfoam/openfoam2306/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam22symGaussSeidelSmoother6smoothERKNS_4wordERNS_5FieldIdEERKNS_9lduMatrixERKS5_RKNS_10FieldFieldIS4_dEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEEhi+0x240)[0x7f41ff1aeb50] [lrhae-HP-290:04588] [ 5] /usr/lib/openfoam/openfoam2306/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam22symGaussSeidelSmoother6smoothERNS_5FieldIdEERKS2_hi+0x5c)[0x7f41ff1aed3c] [lrhae-HP-290:04588] [ 6] /usr/lib/openfoam/openfoam2306/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam12smoothSolver5solveERNS_5FieldIdEERKS2_h+0x4b1)[0x7f41ff1aaef1] [lrhae-HP-290:04588] [ 7] /usr/lib/openfoam/openfoam2306/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(+0x4b5cd6)[0x7f420147ecd6] [lrhae-HP-290:04588] [ 8] /usr/lib/openfoam/openfoam2306/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZNK4Foam6fvMesh5solveERNS_8fvMatrixINS_6VectorIdEEEERKNS_10dictionaryE+0x28)[0x7f4201462448] [lrhae-HP-290:04588] [ 9] pimpleFoam(+0x1f817)[0x55968bb78817] [lrhae-HP-290:04588] [10] /lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7f41fe81ad90] [lrhae-HP-290:04588] [11] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7f41fe81ae40] [lrhae-HP-290:04588] [12] pimpleFoam(+0x22e15)[0x55968bb7be15] [lrhae-HP-290:04588] ***** End of error message ***** -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun noticed that process rank 1 with PID 0 on node lrhae-HP-290 exited on signal 8 (Floating point exception).
