Hello everyone,
I’d like to share an issue I recently encountered while working on a fluid-structure interaction (FSI) simulation using preCICE. The problem appears when I start running the fluid participant in parallel.
This is part of the log I get:
---[precice] Setting up primary communication to coupling partner/s
---[precice] Primary ranks are connected
---[precice] Setting up preliminary secondary communication to coupling partner/s
---[precice] Prepare partition for mesh FluidMesh
---[precice] Gather mesh FluidMesh
---[precice] Send global mesh FluidMesh
---[precice] Receive global mesh StructureMesh
---[precice] Broadcast mesh StructureMesh
---[precice] Filter mesh StructureMesh by bounding box on secondary ranks
---[precice] Mapping distance min:2.77556e-17 max:0.0197826 avg: 0.00954335 var: 3.27548e-05 cnt: 1890
---[precice] WARNING: 16082 of 17626 vertices of mesh StructureMesh have been filtered out since they have no influence on the mapping.
---[precice] Filter mesh StructureMesh by mappings
---[precice] Feedback distribution for mesh StructureMesh
---[precice] Setting up secondary communication to coupling partner/s
---[precice] Secondary ranks are connected
---[precice] Computing "nearest-neighbor" mapping from mesh "StructureMesh" to mesh "FluidMesh" in "read" direction.
---[precice] Mapping "Displacements" for t=0 from "StructureMesh" to "FluidMesh" (skipped zero sample)
---[precice] iteration: 1 of 100 (min 1), time-window: 1 of 10, time: 0, time-window-size: 0.005, max-time-step-size: 0.005, ongoing: yes, time-window-complete: no, write-initial-data write-iteration-checkpoint
I’m not sure whether this warning could affect the convergence of my simulation — which, in fact, is currently not converging.
At the moment, I’m using a nearest-neighbor mapping strategy, with the following configuration:
participant name="FluidSolver">
<provide-mesh name="FluidMesh" />
<receive-mesh name="StructureMesh" geometric-filter="on-secondary-ranks" from="SolidSolver" safety-factor="5."/>
<read-data name="Displacements" mesh="FluidMesh"/>
<write-data name="Pressure" mesh="FluidMesh"/>
<mapping:nearest-neighbor direction="read" from="StructureMesh"
to="FluidMesh" constraint="consistent"/>
</participant>
<participant name="SolidSolver">
<provide-mesh name="StructureMesh" />
<receive-mesh name="FluidMesh" geometric-filter="on-secondary-ranks" from="FluidSolver" safety-factor="5."/>
<write-data name="Displacements" mesh="StructureMesh"/>
<read-data name="Pressure" mesh="StructureMesh"/>
<mapping:nearest-neighbor direction="read" from="FluidMesh"
to="StructureMesh" constraint="consistent"/>
Interestingly, when I switch to rbf mapping, the warning disappears — however, I encounter another error due to duplicate points in my FluidMesh. I tried isolating only one of these duplicate geometry points for coupling, but the error persists.
Does anyone have experience with a similar issue? Could this filtering warning with nearest-neighbor be a reason for the lack of convergence?
NB: On the solid side, I’m using the deal.II adapter as the participant.
