Data (*) on mesh (**) didn't contain any data samples while attempting to map to mesh (***)
Simulation crashed at the same time-window. Now thing’s getting strange. So far have tried serial-explicit, parallel-explicit, parallel-implicit. Both nearest-neighbor and rbf are tested. The OpenFOAM participant runs in serial or parallel MPI mode. All the runs crashed at the same time-window.
The “meshes” causing trouble are 1D line segment (HOS-Coupling-Mesh and OpenFOAM-Coupling-Mesh), at the crashing time the coupling data (etaVOF) is almost zero everywhere on the line mesh (error message: etaVOF on mesh OpenFOAM-Coupling-Mesh didn’t contain any data samples while attempting to map to mesh HOS-Coupling-Mesh).
Update: I managed to complete one run this morning. In this configuration, the output interval dt_out​ is not a multiple of the preCICE time window size dt. In all other failed runs, dt_out has always been a multiple of dt.
When dt_out is not an integer multiple of dt, the time step size dt1 passed to precice.advance(dt1) is not always consistent with the predefined time window size. This results in fine adjustments near output timestamps. I am unsure whether this has contributed to the crashes.
At the end of the successful run this morning, the potential code participant (using the Fortran binding) reported an error stating: “The preCICE library has not been properly initialized. precicef_initialize() must be called before any other preCICE calls.” The process then hung without a proper exit.
I have double-checked my code and found no violations of this initialization rule. Could you please advise on the possible cause? Many thanks!
Update, by setting adjustTimeStep=true to enable variable stepsizes for both participants, I can avoid the crashing. Instead, using same fixed stepsize for both solvers the coupling will crash at a certain time-window when the time-window-size is a multiple time of that stepsize.
Final update, after allowing the participants to adjust their own stepsizes (adjustTimeStep=true), I have tested the following configurations and they all completed succesfully without error.
number of participants: 2, 3, 4
Coupling schemes: serial-explicit, parallel-explicit, parallel-implicit
Mapping methods: rbf, nearest-neigbours
numer of CPUs for each participant: 1-48 (parallel using openmpi)
With the same <mesh> didn't contain any data samples, or with a different error?
That’s interesting. Both solvers are OpenFOAM-based, right?
Sounds like the adjustTimeStep=true is always required, but I am a bit puzzled on how this has not been reported before.
Could you please open an issue in the OpenFOAM adapter with a summary of your observations?
With the same <mesh> didn't contain any data samples , or with a different error?
Same error. All the crashing errors that I mentioned in this thread are the same one.
In my coupling, the master participant is a in-house potential theory based spectral solver. The slave participant(s) is(are) OpenFOAM-based.
In your code, do you adjust the time step size, similarly to the documentation?
dt = min(preciceDt, solverDt);
Yes, I did the similar thing in my own code as what’s been done in the OpenFOAM adaptor.
This is interesting, and might still be a bug in preCICE itself. Just to be sure, could you please post the version information from your logs of both solvers? In your first logs, it looked like this:
# log. HOS
---[precice] This is preCICE version 3.1.2
---[precice] Revision info: no-info [git failed to run]
# log.hosCoupleFoam
For convenience to other readers, I attach the tail of your logs:
# log. HOS
---[precice]  Time window completed
---[precice]  Mapping "etaVOF" for t=68.34 from "OpenFOAM-Coupling-Mesh" to "HOS-Coupling-Mesh"
---[precice]  Mapping "etaVOFShifted" for t=68.34 from "OpenFOAM-Coupling-Mesh" to "HOS-Coupling-Mesh"
---[precice]  Mapping "wVOF" for t=68.34 from "OpenFOAM-Coupling-Mesh" to "HOS-Coupling-Mesh"
---[precice]  Mapping "weights" for t=68.34 from "OpenFOAM-Coupling-Mesh" to "HOS-Coupling-Mesh"
---[precice]  iteration: 1, time-window: 6835, time: 68.34 of 100, time-window-size: 0.01, max-time-step-size: 0.01, ongoing: yes, time-window-complete: yes
 HOS-Coupling: Time advanced.
... <solver logs> ...
---[precice] ERROR:  Data etaVOF on mesh OpenFOAM-Coupling-Mesh didn't contain any data samples while attempting to map to mesh HOS-Coupling-Mesh. Check your exchange tags to ensure your coupling scheme exchanges the data or the pariticipant produces it using an action. The expected exchange tag should look like this: <exchange data="etaVOF" mesh="OpenFOAM-Coupling-Mesh" from=... to=... />.
# log.hosCoupleFoam
---[preciceAdapter] [DEBUG] Advancing preCICE...
---[precice]  Mapping "UHOS" for t=68.35000000000001 from "HOS-Relaxation-Mesh" to "OpenFOAM-Relaxation-Mesh"
---[precice]  Mapping "etaHOS" for t=68.35000000000001 from "HOS-Relaxation-Mesh" to "OpenFOAM-Relaxation-Mesh"
---[precice]  iteration: 1, time-window: 6836, time: 68.35 of 100, time-window-size: 0.01, max-time-step-size: 0.01, ongoing: yes, time-window-complete: yes
---[preciceAdapter] [DEBUG] Adjusting the solver's timestep...
---[preciceAdapter] [DEBUG] The solver's timestep is the same as the coupling timestep.
---[preciceAdapter] [DEBUG] Reading coupling data associated to the calculated time-step size...
---[preciceAdapter] [DEBUG] Reading coupling data...
---[preciceAdapter] [DEBUG] precice_.readData() done for: etaHOS on OpenFOAM-Relaxation-Mesh
---[preciceAdapter] [DEBUG] couplingDataReader->read() done for: etaHOS on OpenFOAM-Relaxation-Mesh
---[preciceAdapter] [DEBUG] precice_.readData() done for: UHOS on OpenFOAM-Relaxation-Mesh
---[preciceAdapter] [DEBUG] couplingDataReader->read() done for: UHOS on OpenFOAM-Relaxation-Mesh
Courant Number mean: 0.00310636354339 max: 0.0873743703009
Interface Courant Number mean: 8.33957199729e-05 max: 0.0621531512312
Time = 68.36
ExecutionTime = 7979.87 s  ClockTime = 7976 s
---[preciceAdapter] [DEBUG] Writing coupling data...
---[preciceAdapter] [DEBUG] couplingDataWriter->write() done for: etaVOF on OpenFOAM-Coupling-Mesh
---[preciceAdapter] [DEBUG] precice_.writeData() done for: etaVOF on OpenFOAM-Coupling-Mesh
<end of logs>
I compiled (outside Spack) from the source which was downloaded from the develop branch at
https://github.com/precice/precice
But still got
This is now system-dependent, but could you somehow verify that no other preCICE installation is being picked up?
from the ldd.log after compiling the OpenFOAM adaptor, I got this:
libprecice.so.3 => /scratcha-fdgs/lux/OpenFOAM/lux-v2106/platforms/precice-develop/platforms/lib64/libprecice.so.3 (0x00007fd1df9dc000)
Which is definitely not the one compiled in Spack. Can this be used as a prove?
This is expected when compiling preCICE from an archive which doesn’t contain any git-related information.
My best guess it that the spack environment isn’t loaded correctly, and the adapter uses the wrong preCICE library for some reason.
The following tool is invaluable at debugging this kind of problem as it tells you where dynamic libraries are loaded from and why:
Tried libtree, output of both participants confirms the correct develop branch dynamic library libprecice.so.3 is loaded.
[lux@fdgs00-ws lib]$ libtree -p /scratcha-fdgs/lux/OpenFOAM/lux-v2106/platforms/linux64GccDPInt32Opt/bin/HOS-coupling
├── /scratcha-fdgs/lux/OpenFOAM/lux-v2106/platforms/precice-develop/platforms/lib64/libprecice.so.3 [LD_LIBRARY_PATH]
│   ├── /scratcha-fdgs/lux/OpenFOAM/spack/opt/spack/linux-centos7-cascadelake/gcc-10.2.1/openmpi-4.1.5-5o5zqlbyuvucgddtu5yybuufh42fpkuc/lib/libmpi.so.40 [rpath]
[lux@fdgs00-ws lib]$ libtree libpreciceAdapterFunctionObject.so -p
We are currently in the process of releasing preCICE version 3.2.0, you could use the current release branch to ensure you have a recent version.
git clone --branch=release-v3.2.0 https://github.com/precice/precice.git
# or
wget https://github.com/precice/precice/archive/refs/heads/release-v3.2.0.zip
Using this version, the logs should contain:
---[precice] This is preCICE version 3.2.0
