Hello preCICE-rs!
I am trying to run an OpenFOAM simulation using boundary values provided by python. To get an understanding of how to perform this using preCICE adapter, I tried to modify the partitioned-pipe tutorial as I wanted to avoid FEniCS installation just for the test.
This test is composed of 2 steps:
- Coupled simulation using the two pimpleFoam solvers:
During this step, the solution of the Fluid2 pimpleFoam solver is stored for each iteration of the simulation using theexport:csvoption.
<participant name="Fluid2">
<export:csv every-iteration="true" directory="./fluid2-output" />
</participant>
- Coupling the Fluid1 pimpleFoam solver with Fluid2 python pseudo-solver:
A python pseudo-solver (“pseudo” because no actual calculation takes place in the python script) reads the pressure data stored in thefluid2-openfoam-pimplefoam/fluid2-outputdirectory and supply the data to the Fluid1 pimpleFOAM solver.
Here is a graphics of the configuration for the steps 1 (top) and 2 (bottom):
Here is the python script that serves as the pseudo-solver in step 2:
from __future__ import division, print_function
import numpy as np
import os
import sys
import argparse
import glob
import pandas as po
import precice
from precice import action_write_initial_data, \
action_read_iteration_checkpoint, action_write_iteration_checkpoint
# UTILITY FUNCTION(S)
def loadParallelCSV(fileID):
return po.concat([po.read_csv(name, sep=";") for name in glob.glob(f"{fileID}_*.csv")],
ignore_index=True)
def loadSerialCSV(fileID):
return po.read_csv(f"{fileID}.csv", sep=";")
# INPUT
print("Starting Fluid2 Solver...")
parser = argparse.ArgumentParser(description='Fluid2 pseudo-solver')
parser.add_argument('-c', '--configurationFileName',
help="Name of the xml config file.",
nargs='?',
type=str,
default="precice-config.xml")
parser.add_argument('-p', '--parentDIR',
help="Location where the code is launched.",
nargs='?',
type=str)
try:
args = parser.parse_args()
except SystemExit:
print("preCICE configuration file not specified")
quit()
inputPATH = os.path.join(args.parentDIR,'..',
'fluid2-openfoam-pimplefoam','fluid2-output')
inputStr = os.path.join(inputPATH, 'Fluid2-Mesh-Fluid2')
# SOLVER
print("Configure preCICE...")
solver_process_index = 0
solver_process_size = 1
interface = precice.Interface("Fluid2", args.configurationFileName,
solver_process_index, solver_process_size)
print("preCICE configured...")
#- Read init
pointData = loadSerialCSV(inputStr+'.init')
N = len(pointData.index)
dimensions = interface.get_dimensions()
pressure = pointData['Pressure'].to_numpy()
meshID = interface.get_mesh_id("Fluid2-Mesh")
velocityID = interface.get_data_id("Velocity", meshID)
pressureGradientID = interface.get_data_id("PressureGradient", meshID)
pressureID = interface.get_data_id("Pressure", meshID)
vertexIDs = np.zeros(N + 1)
grid = pointData[['PosX', 'PosY', 'PosZ']].to_numpy()
vertexIDs = interface.set_mesh_vertices(meshID, grid)
t = 0
it = 1
print("FLuid2: initialize preCICE...")
#- preCICE defines timestep size of solver via precice-config.xml
precice_dt = interface.initialize()
if interface.is_action_required(action_write_initial_data()):
interface.write_block_scalar_data(pressureID, vertexIDs, pressure)
interface.mark_action_fulfilled(action_write_initial_data())
interface.initialize_data()
if interface.is_read_data_available():
#- NOTE: velocity and pressureGradient are imported but not used
velocity = interface.read_block_vector_data(velocityID, vertexIDs)
pressureGradient = interface.read_block_scalar_data(pressureGradientID, vertexIDs)
while interface.is_coupling_ongoing():
#- When an implicit coupling scheme is used, checkpointing is required
if interface.is_action_required(action_write_iteration_checkpoint()):
interface.mark_action_fulfilled(action_write_iteration_checkpoint())
pointData = loadSerialCSV(inputStr+'.it'+str(it))
precice_dt = interface.advance(precice_dt)
#- Not yet converged
if interface.is_action_required(action_read_iteration_checkpoint()):
interface.mark_action_fulfilled(action_read_iteration_checkpoint())
#- Converged, timestep complete
else:
t += precice_dt
it += 1
print("Exiting Fluid2-pseudoSolver")
interface.finalize()
With this setup, the number of iterations is much higher than the original pimpleFoam-pimpleFoam coupling. The python pseudo-solver terminates because it runs out of pressure data to read from the output of the previous simulation in step 1:
---[precice] ^[[0m iteration: 26 of 100, time-window: 5, time: 0.04 of 1, time-window-size: 0.01, max-timestep-length: 0.01, ongoing: yes, time-window-complete: no, read-iteration-checkpoint
---[precice] ^[[0m relative convergence measure: relative two-norm diff of data "Pressure" = 6.22e-05, limit = 1.00e-06, normalization = 1.45e+02, conv = false
---[precice] ^[[0m relative convergence measure: relative two-norm diff of data "Velocity" = 2.53e-08, limit = 1.00e-06, normalization = 2.61e+00, conv = true
---[precice] ^[[0m iteration: 27 of 100, time-window: 5, time: 0.04 of 1, time-window-size: 0.01, max-timestep-length: 0.01, ongoing: yes, time-window-complete: no, read-iteration-checkpoint
---[precice] ^[[0m relative convergence measure: relative two-norm diff of data "Pressure" = 6.24e-05, limit = 1.00e-06, normalization = 1.45e+02, conv = false
---[precice] ^[[0m relative convergence measure: relative two-norm diff of data "Velocity" = 1.14e-08, limit = 1.00e-06, normalization = 2.61e+00, conv = true
---[precice] ^[[0m iteration: 28 of 100, time-window: 5, time: 0.04 of 1, time-window-size: 0.01, max-timestep-length: 0.01, ongoing: yes, time-window-complete: no, read-iteration-checkpoint
FileNotFoundError: [Errno 2] No such file or directory: '/scratch/nkumar001/OpenFOAM/nkumar001-6/run/precice.partitioned-pipe.of-py.run20230215/fluid2-python/../fluid2-openfoam-pimplefoam/fluid2-output/Fluid2-Mesh-Fluid2.it330.csv'
---[precice] ^[[0m Implicitly finalizing in destructor
The error above basically states that the data at iteration number 330 was not found as the previous iteration saved data only until iteration number 329, at which the simulation terminated. Note that the preCICE configuration file remains the same as that provided in the tutorial for this coupling.
I have two questions in this regard:
- Is this a good test to check the coupling between OpenFOAM and python? I am not sure if the precision of the exported data affects the convergence of the OpenFOAM solver?
- Is there something I need to modify in the
interface.is_coupling_ongoingloop in the python script to make this coupling work?
I understand that the coupling of OpenFOAM and python has previously been attempted, as hinted here: Using preCICE to couple python and OpenFOAM - #3 by Makis. Any input in this regard will be very helpful.
Thanks in advance.
