Compiling v3.2.0 failed (unity build)
cmake configuration completed with no error, but got errors in make stage. Log files are attached. Thanks for your help.
Configuration.log (10.1 KB)
make.log (2.4 KB)
[lux@fdgs00-ws build]$ make
[  2%] Built target fmtlib-static
-- Found Git: /usr/bin/git (found version "1.8.3.1")
-- Revision status: v3.1.2-303-g2aa8ac8
[  2%] Built target GitRevision
[  3%] Building CXX object CMakeFiles/preciceCore.dir/Unity/unity_cplscheme_cxx.cxx.o
/opt/rh/devtoolset-9/root/usr/include/c++/9/bits/stl_algo.h(4337): error: no instance of function template "std::_Mem_fn<_Res _Class::*>::operator() [with _Res=precice::cplscheme::CouplingScheme *() noexcept, _Class=std::__shared_ptr<precice::cplscheme::CouplingScheme, __gnu_cxx::_S_atomic>]" matches the argument list
            argument types are: (const precice::cplscheme::PtrCouplingScheme)
            object type is: std::_Mem_fn<precice::cplscheme::CouplingScheme *(std::__shared_ptr<precice::cplscheme::CouplingScheme, __gnu_cxx::_S_atomic>::*)() const noexcept>
   *__result = __unary_op(*__first);
/opt/rh/devtoolset-9/root/usr/include/c++/9/functional(135): note #3327-D: candidate function template "std::_Mem_fn_base<_MemObjPtr, false>::operator() [with _MemObjPtr=precice::cplscheme::CouplingScheme *(std::__shared_ptr<precice::cplscheme::CouplingScheme, __gnu_cxx::_S_atomic>::*)() const noexcept]" failed deduction
   operator()(_Tp&& __obj) const
          detected during instantiation of "_OIter std::transform(_IIter, _IIter, _OIter, _UnaryOperation) [with _IIter=__gnu_cxx::__normal_iterator<const precice::cplscheme::PtrCouplingScheme *, std::vector<precice::cplscheme::PtrCouplingScheme, std::allocator<precice::cplscheme::PtrCouplingScheme>>>, _OIter=__gnu_cxx::__normal_iterator<precice::cplscheme::CouplingScheme **, std::vector<precice::cplscheme::CouplingScheme *, std::allocator<precice::cplscheme::CouplingScheme *>>>, _UnaryOperation=std::_Mem_fn<precice::cplscheme::CouplingScheme *(std::__shared_ptr<precice::cplscheme::CouplingScheme, __gnu_cxx::_S_atomic>::*)() const noexcept>]" at line 478 of /scratcha-fdgs/lux/OpenFOAM/lux-v2106/platforms/precice-3.2.0/src/cplscheme/CompositionalCouplingScheme.cpp
1 error detected in the compilation of "/scratcha-fdgs/lux/OpenFOAM/lux-v2106/platforms/precice-3.2.0/build/CMakeFiles/preciceCore.dir/Unity/unity_cplscheme_cxx.cxx".
make[2]: *** [CMakeFiles/preciceCore.dir/build.make:146: CMakeFiles/preciceCore.dir/Unity/unity_cplscheme_cxx.cxx.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:170: CMakeFiles/preciceCore.dir/all] Error 2
make: *** [Makefile:166: all] Error 2
@Ya_Squall sounds like a bug, please open an issue in the preCICE repository and link from this thread.
You can try passing -DPRECICE_BUILD_UNITY=OFF to cmake and see if that already helps.
with -DPRECICE_BUILD_UNITY=OFF, I got new errors. Please check the attached log file.
cmake.log (104.4 KB)
issue resolved, see [preCICE repository].
