HI:
I am going to use other interpolation algorithms in the adapter and then pass the interpolated data to precice for acceleration, I don’t know if it is feasible? (i.e. not using precice’s mapping interpolation, but my own)
anybody can answer me,?very thanks
What are you interpolating inside your adapter? If you are referring to interpolation between meshes of the participants that you are coupling, how are you accessing the meshes in one adapter? Are you using the direct access to received meshes feature?
yes,I will use using the direct access to received meshes feature,but I want to known Can I use precice’s acceleration algorithm normally?
Yes you can.
very thanks, I will test it
