3D volume interpolation schemes
I recently started using the OpenFOAM adapter for preCICE coupling and encountered an issue. Since linear-interpolation between two grids requires a defined mesh-connectivity I need to set the connectivity = true; flag in the preciceDict file for my Interface.
The documentation states that this parameter can only be true for locations faceNodes. Is there another option to interpolate data when using the OpenFOAM adapter with 3D volumes except RBF-kernels?
I did not try the cuda parallelized version of RBFs but running this on the GPU requires more patience than i can provide :sweat_smile:
This is my current precice-config.xml if anyone is interested. When analyzing the precice.log file i see that mapping defaults to nearest-neighbor for the written Forces.
<?xml version="1.0" encoding="UTF-8"?>
<precice-configuration>
  <log>
    <sink type="file" output="precice.log" filter="%Severity% > debug and %Rank% = 0"
      format="(%Rank%) [%Module%]:%Line% in %Function%: %Severity% %Message%" enabled="true" />
  </log>
  <data:vector name="Velocity" />
  <data:vector name="Forces" />
  <mesh name="DEMGrid" dimensions="3">
    <use-data name="Velocity" />
    <use-data name="Forces" />
  </mesh>
  <mesh name="FluidMesh" dimensions="3">
  </mesh>
  <participant name="XPSSolver">
    <provide-mesh name="DEMGrid" />
    <receive-mesh name="FluidMesh" from="FluidSolver" />
    <!-- Read velocity: nearest-neighbor -->
    <mapping:nearest-neighbor
      direction="read"
      from="FluidMesh"
      to="DEMGrid"
      constraint="consistent" />
    <!-- Write momentum source: linear-cell-interpolation -->
    <mapping:linear-cell-interpolation
      direction="write"
      from="DEMGrid"
      to="FluidMesh"
      constraint="conservative" />
    <read-data name="Velocity" mesh="DEMGrid" />
    <write-data name="Forces" mesh="DEMGrid" />
  </participant>
  <participant name="FluidSolver">
    <provide-mesh name="FluidMesh" />
    <receive-mesh name="DEMGrid" from="XPSSolver" />
    <read-data name="Forces" mesh="FluidMesh" />
    <write-data name="Velocity" mesh="FluidMesh" />
  </participant>
  <m2n:sockets acceptor="FluidSolver" connector="XPSSolver" exchange-directory="../" />
    <participants first="XPSSolver" second="FluidSolver" />
    <max-time value="1.0" />
    <time-window-size value="1e-3" />
    <exchange data="Velocity" mesh="FluidMesh" from="FluidSolver" to="XPSSolver" />
    <exchange data="Forces" mesh="FluidMesh" from="XPSSolver" to="FluidSolver" />
</precice-configuration>
I am using preCICE 3.20 on Fedora 41 and the current master of the OpenFOAM-adapter.
Why do you want to specifically exclude kernel methods for the mapping? The GPU variant you are referring to is most likely not suitable for a volumetric coupling, but the pu-rbf variant is.
Based on your configuration, I guess the following discussion could also be of interest Volume coupling to particle tracker
Hello David,
thanks for your reply! I am not against using kernel methods for mapping but was asking myself if a less computationally costly option (such as trilinear-interpolation) could also work to speed up my test-setup during implementation.
I will take a look at the discussion you provided - thanks a lot
