# Installation problem with CalculiX-2.19 adapter
**URL:** <https://precice.discourse.group/t/installation-problem-with-calculix-2-19-adapter/1124>\
**Category:** Official adapters and tutorials\
**Tags:** adapters, calculix\
**Created:** [August 3, 2022, 4:39pm UTC](https://precice.discourse.group/t/installation-problem-with-calculix-2-19-adapter/1124 "2022-08-03T16:39:07Z")\
**Showing post:** 8
**Author:** ![boris-martin](https://yyz2.discourse-cdn.com/free1/user_avatar/precice.discourse.group/boris-martin/32/705_2.png) [@boris-martin](https://precice.discourse.group/u/boris-martin)\
**Post date:** [August 3, 2022, 8:35pm UTC](https://precice.discourse.group/t/installation-problem-with-calculix-2-19-adapter/1124/8 "2022-08-03T20:35:05Z")
Among other things, the old adapter can’t run modal dynamic simulations (see if you can run the tutorial proposed at [Modal dynamic simulation of the perpendicular flap with CalculiX by boris-martin · Pull Request #284 · precice/tutorials · GitHub](https://github.com/precice/tutorials/pull/284) ) nor simulations involving hexaedral elements with nodal meshes (see if you can run [Added CalculiX case for flow-over-heated-plate by boris-martin · Pull Request #271 · precice/tutorials · GitHub](https://github.com/precice/tutorials/pull/271) )
Also, running ccx\_preCICE --version should be a hint. I’m not sure if it would give the CalculiX version or the adapter version.
_[View the full topic](https://precice.discourse.group/t/installation-problem-with-calculix-2-19-adapter/1124)._
