# Collapsible Tube (OpenFOAM+CalculiX)
**URL:** <https://precice.discourse.group/t/collapsible-tube-openfoam-calculix/1334>\
**Category:** Official adapters and tutorials\
**Tags:** openfoam, calculix, fsi\
**Created:** [March 20, 2023, 3:50pm UTC](https://precice.discourse.group/t/collapsible-tube-openfoam-calculix/1334 "2023-03-20T15:50:59Z")\
**Showing post:** 32
**Author:** ![mishal49](https://avatars.discourse-cdn.com/v4/letter/m/e9c0ed/32.png) [@mishal49](https://precice.discourse.group/u/mishal49)\
**Post date:** [April 28, 2023, 6:34pm UTC](https://precice.discourse.group/t/collapsible-tube-openfoam-calculix/1334/32 "2023-04-28T18:34:50Z")
> [@Makis](#):
> - You are (correctly) exchanging both force and relative displacement, but (based on the `preciceDict` I saw before) you are not reading those displacements.
> - You are writing displacements from CalculiX, but not reading them in OpenFOAM, which looks unmotivated.
> - You are (correctly) using an implicit coupling scheme, but this requires a bi-directional coupling to work, as it is based on iterations and corrections. If one participant always gives the same values, preCICE will complain.
I changed this.
Please find attached the preciceDict, precice-config.xml and config.yml files:
[preciceDict.txt](https://precice.discourse.group/uploads/short-url/4U3eRBUFdke59eYOlxRp272a09I.txt) (700 Bytes)
[precice-config.xml](https://precice.discourse.group/uploads/short-url/m002KeMJDucC1fCXiacSXivIWNL.xml) (2.9 KB)
[config.yml](https://precice.discourse.group/uploads/short-url/5L4Hktm9wh1dt5DrkJU3MY37lbp.yml) (249 Bytes)
The case still diverged after the first timestep. Please find attached output files:
[foam.out](https://precice.discourse.group/uploads/short-url/RSCBQkVX2FBNeCPLKlrAxZR1Ea.out) (70.4 KB)
[calculix.out](https://precice.discourse.group/uploads/short-url/bD3Y8us0wvq1HGbjgqXjHe9ERSd.out) (56.7 KB)
_[View the full topic](https://precice.discourse.group/t/collapsible-tube-openfoam-calculix/1334)._
